TwinTurbo.NET: Nissan 300ZX forum - The safest thing to do...
Subject The safest thing to do...
Posted by zeeway on July 04, 2008 at 5:28 AM
  This message has been viewed 181 times.
In Reply To Should I get a new crankshaft oil seal? posted by turbo1 on July 04, 2008 at 03:52 AM
Message of course, is to get a new seal. How would you feel if you had to pull the tranny again (presuming you don't have engine out)?
On the other hand...if you are a gambler...the outer diameter of the outer shell of the seal must be in tact to seal, and the rubber lip must not be damaged or distorted in any way to seal correctly. If the inner ring is slightly dinged...and neither the outer shell diameter or the rubber sealing element surface is distorted...you are probably okay.
However, the safest thing to do is...replace the seal.
____________________________________________________
__zeeway__
